650X dial drive removel.
Bill, let me play with the one off my parts set. BTW, the one in my 650X is slightly rough. Not much, but I believe it's the shaft itself. I'll get back to you on this.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
650X dial drive removel. - by wonderwrench - 07-27-2008, 08:28 PM
[No subject] - by Ron Ramirez - 07-27-2008, 11:46 PM
[No subject] - by BDM - 07-28-2008, 11:49 PM
[No subject] - by etech - 07-29-2008, 01:05 AM
[No subject] - by wonderwrench - 07-30-2008, 02:18 PM
[No subject] - by BDM - 07-30-2008, 05:49 PM
[No subject] - by BDM - 07-30-2008, 09:21 PM
[No subject] - by wonderwrench - 07-31-2008, 05:01 PM
[No subject] - by BDM - 07-31-2008, 05:20 PM
[No subject] - by wonderwrench - 07-31-2008, 09:30 PM
There are currently 10384 online users. [Complete List]
» 3 Member(s) | 10381 Guest(s)
