Best Philco Tombstone for the Money
I dont know.. but my 37-610 tombstone is great at pulling in far away stations. Even pulls in things my RCA 816k Won't do!
Best Philco Tombstone for the Money - by Jayce - 04-24-2014, 02:35 PM
RE: Best Philco Tombstone for the Money - by PhilcoJohn - 04-24-2014, 07:09 PM
Philco 91 Tuning Condenser
There are currently 6171 online users. [Complete List]
» 2 Member(s) | 6169 Guest(s)
