Philco 60 Cabinet Suggestions
Hi guys,
I just finished the electrical work on my Philco 60, and it is playing nicely. However, I'm torn as to what to do with the cabinet.
Looking at the wear pattern, it's clear that this was a well used and well loved set. I would hate to lose all of that character by completely stripping it. Still, the finish is tired and the sides show some cracking.
Any suggestions on what route to take?
Philco 60 Cabinet Suggestions - by Roger Cole - 04-24-2014, 11:12 PM
RE: Philco 60 Cabinet Suggestions - by Warren - 04-24-2014, 11:59 PM
RE: Philco 60 Cabinet Suggestions - by Jamie - 04-25-2014, 06:18 AM
Philco 91 Tuning Condenser
There are currently 5349 online users. [Complete List]
» 1 Member(s) | 5348 Guest(s)
