Hit the Jackpot Today !! 38-690 !
Very nice!!! .. That's my dream radio. If I ever find one, I will probably spend a year of my life making it perfect.
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 04-24-2014, 04:42 PM
RE: Hit the Jackpot Today !! 38-690 ! - by gregb - 04-24-2014, 05:19 PM
RE: Hit the Jackpot Today !! 38-690 ! - by TimC - 04-25-2014, 12:42 PM
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 04-26-2014, 11:23 AM
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 04-26-2014, 03:20 PM
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 05-13-2014, 08:18 PM
RE: Philco 38-690 chassis pics as requested - by Jamie - 04-25-2014, 06:31 AM
There are currently 10080 online users. [Complete List]
» 2 Member(s) | 10078 Guest(s)
