650X dial drive removel.
Bill, yes too much tension will cause roughness as you say. It's pulling up on the shaft. Try loosening it and re-adjusting for slightly less tension. I was playing with my parts set, and I can get it pretty smooth without slippage. Make sure there is NO grease on the tuner turn-stile wire(lack of a better word). It's a little tedious, but just keep doing it ever so slightly.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
650X dial drive removel. - by wonderwrench - 07-27-2008, 08:28 PM
[No subject] - by Ron Ramirez - 07-27-2008, 11:46 PM
[No subject] - by BDM - 07-28-2008, 11:49 PM
[No subject] - by etech - 07-29-2008, 01:05 AM
[No subject] - by wonderwrench - 07-30-2008, 02:18 PM
[No subject] - by BDM - 07-30-2008, 05:49 PM
[No subject] - by BDM - 07-30-2008, 09:21 PM
[No subject] - by wonderwrench - 07-31-2008, 05:01 PM
[No subject] - by BDM - 07-31-2008, 05:20 PM
[No subject] - by wonderwrench - 07-31-2008, 09:30 PM
There are currently 9156 online users. [Complete List]
» 1 Member(s) | 9155 Guest(s)
