Scott 800B
Plays very well! Slight drift on FM until fully warmed up. It features variable sensitivity and selectivity, so it is possible to fully exploit the excellent sound and reception of this set.
Scott 800B - by TA Forbes - 03-25-2014, 09:59 AM
RE: Scott 800B - by BrendaAnnD - 03-25-2014, 10:05 AM
RE: Scott 800B - by y2kbruce - 03-25-2014, 11:38 AM
RE: Scott 800B - by morzh - 03-25-2014, 01:37 PM
RE: Scott 800B - by TA Forbes - 03-25-2014, 02:17 PM
RE: Scott 800B - by morzh - 03-25-2014, 02:46 PM
RE: Scott 800B - by jerryhawthorne - 03-25-2014, 03:13 PM
RE: Scott 800B - by Jayce - 03-25-2014, 08:42 PM
RE: Scott 800B - by BrendaAnnD - 03-25-2014, 11:13 PM
RE: Scott 800B - by TA Forbes - 03-26-2014, 12:03 PM
RE: Scott 800B - by Jayce - 03-26-2014, 01:15 PM
RE: Scott 800B - by y2kbruce - 03-26-2014, 02:49 PM
RE: Scott 800B - by Ron Ramirez - 03-29-2014, 10:06 AM
RE: Scott 800B - by murf - 04-21-2014, 06:04 PM
RE: Scott 800B - by rocklandman - 04-22-2014, 01:44 PM
RE: Scott 800B - by PhilcoJohn - 04-24-2014, 07:15 PM
RE: Scott 800B - by TA Forbes - 04-25-2014, 10:56 AM
RE: Scott 800B - by Eliot Ness - 04-25-2014, 01:57 PM
RE: Scott 800B - by y2kbruce - 04-25-2014, 04:26 PM
