Grill time! Making a replacement grill mold NEW PICS
#38
I think you may have misunderstood, you mix the two different colour batches separately, but at the same time, and then mix them together. This was how they used to cast the catalin sets back in the day and I think it's how Mr Pontrello recreates the marbling effect with epoxy when he repairs catalin cabinets.
RE: Grill time! - by TimC - 02-27-2014, 09:55 PM
RE: Grill time! - by morzh - 02-27-2014, 10:49 PM
RE: Grill time! - by OldRestorer - 02-28-2014, 10:04 AM
RE: Grill time! Making a replacement grill mold (what colors) - by Arran - 04-25-2014, 07:59 PM
Users browsing this thread: 13 Guest(s)
