Silverstone 4763
Typically, that style electrolytic uses a tar like material to secure the actual capacitive element inside the can. It may take considerable heat to melt the tar and free the assembly. I have used a heat gun, which produces a much higher temperature than a hair dryer.
Silverstone 4763 - by PAradiogeek - 04-25-2014, 10:10 PM
RE: Silverstone 4763 - by skyscraper - 04-25-2014, 10:19 PM
RE: Silverstone 4763 - by PAradiogeek - 04-25-2014, 10:22 PM
RE: Silverstone 4763 - by skyscraper - 04-25-2014, 10:24 PM
RE: Silverstone 4763 - by Mondial - 04-25-2014, 10:28 PM
RE: Silverstone 4763 - by PAradiogeek - 04-25-2014, 10:36 PM
RE: Silverstone 4763 - by PAradiogeek - 04-26-2014, 06:25 PM
RE: Silverstone 4763 - by radiohenry - 04-26-2014, 06:41 PM
RE: Silverstone 4763 - by PAradiogeek - 04-26-2014, 09:42 PM
RE: Silverstone 4763 - by Jamie - 04-27-2014, 07:41 AM
RE: Silverstone 4763 - by radiohenry - 04-27-2014, 09:40 AM
