Hit the Jackpot Today !! 38-690 !
If I don't hit any jackpots in the next two years I will overdose on Coors Light, which is extrmely unpleasant way of committing buying the farm.
Of course meantime I could turn green and someone could harvest me by mistake.
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 04-24-2014, 04:42 PM
RE: Hit the Jackpot Today !! 38-690 ! - by gregb - 04-24-2014, 05:19 PM
RE: Hit the Jackpot Today !! 38-690 ! - by TimC - 04-25-2014, 12:42 PM
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 04-26-2014, 11:23 AM
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 04-26-2014, 03:20 PM
RE: Hit the Jackpot Today !! 38-690 ! - by morzh - 05-13-2014, 08:18 PM
There are currently 10384 online users. [Complete List]
» 2 Member(s) | 10382 Guest(s)
