What I brought home
Got these philcos fri and today, along with a bunch of tubes and a portable victrola.
I know the picture is crappy but I am still trying to figure out this Iphone.
What I brought home - by tab10672 - 04-26-2014, 11:29 AM
RE: What I brought home - by morzh - 04-26-2014, 11:32 AM
RE: What I brought home - by tab10672 - 04-26-2014, 11:36 AM
RE: What I brought home - by OldRestorer - 04-26-2014, 02:14 PM
RE: What I brought home - by TA Forbes - 04-26-2014, 02:55 PM
RE: What I brought home - by rocklandman - 04-26-2014, 04:16 PM
RE: What I brought home - by Jayce - 04-26-2014, 04:43 PM
RE: What I brought home - by Jamie - 04-27-2014, 06:44 AM
RE: What I brought home - by Ron Ramirez - 04-27-2014, 08:55 AM
RE: What I brought home - by TA Forbes - 04-27-2014, 09:05 AM
RE: What I brought home - by morzh - 04-27-2014, 10:23 AM
RE: What I brought home - by Radioroslyn - 04-27-2014, 11:04 AM
RE: What I brought home - by tab10672 - 04-27-2014, 03:18 PM
RE: What I brought home - by tab10672 - 04-27-2014, 03:25 PM
RE: What I brought home - by morzh - 04-27-2014, 04:14 PM
RE: What I brought home - by gregb - 04-27-2014, 05:28 PM
