Silverstone 4763
Radiohenry,
On mine, the chassis is rather dark, though I haven't gotten around to trying to clean it up yet. Also all of the labels on mine (both inside the chassis and outside) look burnt. I had assumed they were actually burned or overheated somehow.
In all of my previous restorations, I just disconnected the electrolytic cans and added new caps underneath. I decided to give restuffing a try this time. I'll see how it looks after I finish before I decide to do any others. It is definitely more work.
How many people restuff vs. hide underneath? Curious.
Silverstone 4763 - by PAradiogeek - 04-25-2014, 10:10 PM
RE: Silverstone 4763 - by skyscraper - 04-25-2014, 10:19 PM
RE: Silverstone 4763 - by PAradiogeek - 04-25-2014, 10:22 PM
RE: Silverstone 4763 - by skyscraper - 04-25-2014, 10:24 PM
RE: Silverstone 4763 - by Mondial - 04-25-2014, 10:28 PM
RE: Silverstone 4763 - by PAradiogeek - 04-25-2014, 10:36 PM
RE: Silverstone 4763 - by PAradiogeek - 04-26-2014, 06:25 PM
RE: Silverstone 4763 - by radiohenry - 04-26-2014, 06:41 PM
RE: Silverstone 4763 - by PAradiogeek - 04-26-2014, 09:42 PM
RE: Silverstone 4763 - by Jamie - 04-27-2014, 07:41 AM
RE: Silverstone 4763 - by radiohenry - 04-27-2014, 09:40 AM
There are currently 3088 online users. [Complete List]
» 1 Member(s) | 3087 Guest(s)
