Philco Junior - Model 80 Question
I have a fully unmolested Jr with finish in decent enough shape for me to think that whatever decal might be there woud still be present today at least in part.
Since there is no hint of it, I think there was none.
There is Philco sign on the escutcheon.
Philco Junior - Model 80 Question - by Jamie - 04-27-2014, 04:08 PM
RE: Philco Junior - Model 80 Question - by morzh - 04-27-2014, 04:20 PM
RE: Philco Junior - Model 80 Question - by Jamie - 04-27-2014, 04:26 PM
RE: Philco Junior - Model 80 Question - by morzh - 04-28-2014, 01:50 PM
RE: Philco Junior - Model 80 Question - by Jamie - 04-28-2014, 08:20 PM
RE: Philco Junior - Model 80 Question - by morzh - 04-28-2014, 11:07 PM
RE: Philco Junior - Model 80 Question - by Warren - 04-28-2014, 11:19 PM
RE: Philco Junior - Model 80 Question - by Jamie - 04-29-2014, 07:08 AM
RE: Philco Junior - Model 80 Question - by morzh - 04-29-2014, 10:16 AM
RE: Philco Junior - Model 80 Question - by vwminister - 05-04-2014, 05:31 PM
RE: Philco Junior - Model 80 Question - by KCMike - 05-04-2014, 09:28 PM
RE: Philco Junior - Model 80 Question - by Jamie - 05-06-2014, 05:41 PM
There are currently 10349 online users. [Complete List]
» 1 Member(s) | 10348 Guest(s)
