How do I Prevent "Orange Peel" with Lacquer?
As requested, here is an image. Before this light coat of lacquer from a rattle can, I sanded the previous coat to the proverbial "smoother than a baby's bottom." As this coat was going on, I could immediately see the texture returning. This is very frustrating... Earlier in the week, I was working on restoring the metal frame of a Sonochorde speaker. I ended up sanding the rust from the frame and coating it with this same can of semi-gloss lacquer. I had no problems with the surface texture. I don't get it - what is going on here? The whole surface looks like this.
PuhPow - When/how do you use the Precatalyzed Clear? Do you spray this before you use lacquer, or immediately after the lacquer before it begins to dry?
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 3091 online users. [Complete List]
» 4 Member(s) | 3087 Guest(s)
AvatarAvatarAvatarAvatar
