Best Philco Tombstone for the Money
Thanks Jayce,
The chassis is finished.     I just started on the cabinet. Good luck with your A K.
Eric
The Villages, FL
Best Philco Tombstone for the Money - by Jayce - 04-24-2014, 02:35 PM
RE: Best Philco Tombstone for the Money - by Eric Adams - 04-27-2014, 07:57 PM
Philco 91 Tuning Condenser
There are currently 6005 online users. [Complete List]
» 1 Member(s) | 6004 Guest(s)
