  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#82
Thermal coeff. of copper is about 0.4% per degree C. That is if you have 75 ohm at say 25C then at 36C (which is your body temp) it will become roughly 4% more that of 75 would be 3 ohms. So yes it is close and your hand will bring the resistance of 75 ohms close to 80.
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by morzh - 04-27-2014, 08:03 PM
