Zenith With a Little History
Picked this up at the flea market a couple of weeks ago. Not really a head turner but it was just a few bucks AND had this really cool sticker on the back. Turns out this radio was bought and/or repaired at M.L. Bruner Co. in Santa Rosa, CA which just happened to be the location of the flea market. So the radio stayed pretty much local but I liked the sticker and did a little research on the company. Here is a link to some pictures I came across. Just click on the picture to enlarge.
http://heritage.sonomalibrary.org/cdm/se...der/nosort
Craig R.
Zenith With a Little History - by VntgRads - 04-28-2014, 12:22 AM
RE: Zenith With a Little History - by morzh - 04-28-2014, 10:10 AM
RE: Zenith With a Little History - by Jayce - 04-28-2014, 08:03 PM
