650B RF and Antenna Tuning Characteristics
Ed and I have been discussing this. Really want to hear others opinions.
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
[No subject] - by BDM - 08-01-2008, 11:14 PM
[No subject] - by Ron Ramirez - 08-02-2008, 12:24 AM
[No subject] - by BDM - 08-08-2008, 03:15 PM
There are currently 10560 online users. [Complete List]
» 2 Member(s) | 10558 Guest(s)
