Philco Junior - Model 80 Question
I have noticed that as long as it says philco one time somewhere, weather it is on the dial, escutcheon, or a decal. Since the 80 has philco on the escutcheon then that is the only time it is used. I have not seen any philco with the word used twice besides tube or model decals.
Philco Junior - Model 80 Question - by Jamie - 04-27-2014, 04:08 PM
RE: Philco Junior - Model 80 Question - by morzh - 04-27-2014, 04:20 PM
RE: Philco Junior - Model 80 Question - by Jamie - 04-27-2014, 04:26 PM
RE: Philco Junior - Model 80 Question - by tab10672 - 04-28-2014, 10:43 AM
RE: Philco Junior - Model 80 Question - by morzh - 04-28-2014, 01:50 PM
RE: Philco Junior - Model 80 Question - by Jamie - 04-28-2014, 08:20 PM
RE: Philco Junior - Model 80 Question - by morzh - 04-28-2014, 11:07 PM
RE: Philco Junior - Model 80 Question - by Warren - 04-28-2014, 11:19 PM
RE: Philco Junior - Model 80 Question - by Jamie - 04-29-2014, 07:08 AM
RE: Philco Junior - Model 80 Question - by morzh - 04-29-2014, 10:16 AM
RE: Philco Junior - Model 80 Question - by vwminister - 05-04-2014, 05:31 PM
RE: Philco Junior - Model 80 Question - by KCMike - 05-04-2014, 09:28 PM
RE: Philco Junior - Model 80 Question - by Jamie - 05-06-2014, 05:41 PM
There are currently 10837 online users. [Complete List]
» 2 Member(s) | 10835 Guest(s)
