My new 620B
Thanks for the comments, everyone.
John, I tried rubbing it with denatured, and it's working great! The stuff is really stubborn and takes forever, but the lacquer underneath is in very presentable condition. It looked very dull, but a little bit of Howard's made it much better. Still a few dings and scratches, but much better than before. Thanks for the tip!
Is it safe to use alcohol on the knobs and escutcheon as well?
I'll post another photo once I finish the sides.
My new 620B - by skyscraper - 04-27-2014, 12:16 AM
RE: My new 620B - by Jamie - 04-27-2014, 06:42 AM
RE: My new 620B - by TA Forbes - 04-27-2014, 08:52 AM
RE: My new 620B - by Eliot Ness - 04-27-2014, 11:15 AM
RE: My new 620B - by Radioroslyn - 04-27-2014, 11:39 AM
RE: My new 620B - by PAradiogeek - 04-28-2014, 11:00 AM
RE: My new 620B - by skyscraper - 04-28-2014, 04:03 PM
RE: My new 620B - by Eliot Ness - 04-28-2014, 04:11 PM
RE: My new 620B - by Paul Philco322 - 04-28-2014, 08:13 PM
RE: My new 620B - by skyscraper - 04-29-2014, 01:18 AM
RE: My new 620B - by Eliot Ness - 04-29-2014, 11:52 AM
RE: My new 620B - by skyscraper - 04-29-2014, 12:38 PM
RE: My new 620B - by Arran - 04-29-2014, 09:41 PM
RE: My new 620B - by Arran - 04-29-2014, 09:48 PM
RE: My new 620B - by skyscraper - 04-29-2014, 10:15 PM
Philco 91 Tuning Condenser
There are currently 6744 online users. [Complete List]
» 3 Member(s) | 6741 Guest(s)
