Vibrator Cross Reference?
The Google searches came up with some of the old radio monthly pubs that I downloaded and am happy to get and enjoyed looking at.
They mention a Mallory complete data book or something like that.
I will be on the prowl for that one. If I find one it will get scanned and shared.
use care with the burnish tool. The sh#$y contact appearance is ideal. The surface is peaks & valleys caused by arcs that make better contact in micro seconds than the ones that look smooth. Look into the caps across the contacts. They are "tuned" like the cap in an old distributors across the ignition coil.
Vibrator Cross Reference? - by bfrohwein - 04-22-2014, 08:23 PM
RE: Vibrator Cross Reference? - by Carl Travis - 04-23-2014, 03:43 PM
RE: Vibrator Cross Reference? - by K7Sparky - 04-23-2014, 04:14 PM
RE: Vibrator Cross Reference? - by gregb - 04-23-2014, 05:34 PM
RE: Vibrator Cross Reference? - by bfrohwein - 04-23-2014, 05:37 PM
RE: Vibrator Cross Reference? - by K7Sparky - 04-28-2014, 06:57 PM
RE: Vibrator Cross Reference? - by K7Sparky - 05-25-2014, 03:43 PM
RE: Vibrator Cross Reference? - by bfrohwein - 05-25-2014, 05:29 PM
RE: Vibrator Cross Reference? - by K7Sparky - 05-25-2014, 07:19 PM
RE: Vibrator Cross Reference? - by bfrohwein - 05-25-2014, 10:26 PM
RE: Vibrator Cross Reference? - by joybird - 05-27-2014, 03:32 PM
There are currently 10434 online users. [Complete List]
» 1 Member(s) | 10433 Guest(s)
