37-690 speaker wire
Hi
The 20 gauge unrated wire from Radio Daze should do just fine for this application. 10 gauge would be major overkill.
This page should prove enlightening.
http://www.powerstream.com/Wire_Size.htm
37-690 speaker wire - by wonderwrench - 07-31-2008, 06:29 PM
[No subject] - by wonderwrench - 08-02-2008, 05:46 PM
[No subject] - by Ron Ramirez - 08-02-2008, 06:34 PM
[No subject] - by wonderwrench - 08-02-2008, 07:00 PM
[No subject] - by wonderwrench - 08-04-2008, 12:13 PM
