My new 620B
After nearly two hours and half a bottle of poisoned moonshine later, I got all the shellac off. It looks significantly better than before, but it's easy to see why they did it in the first place. The lacquer underneath is in rough condition in several places. I still may end up refinishing it later, but for now I think it looks fine.
It was a protectant, now I wish they had put it on earlier Icon_wink
Before and after:
[Image: https://lh4.googleusercontent.com/-L4Kqr...C_8109.jpg][Image: https://lh4.googleusercontent.com/-Ud_Lb...C_8116.JPG]
It's worst on the top:
[Image: https://lh4.googleusercontent.com/-8EdSA...C_8117.JPG]
Will
My new 620B - by skyscraper - 04-27-2014, 12:16 AM
RE: My new 620B - by Jamie - 04-27-2014, 06:42 AM
RE: My new 620B - by TA Forbes - 04-27-2014, 08:52 AM
RE: My new 620B - by Eliot Ness - 04-27-2014, 11:15 AM
RE: My new 620B - by Radioroslyn - 04-27-2014, 11:39 AM
RE: My new 620B - by PAradiogeek - 04-28-2014, 11:00 AM
RE: My new 620B - by skyscraper - 04-28-2014, 04:03 PM
RE: My new 620B - by Eliot Ness - 04-28-2014, 04:11 PM
RE: My new 620B - by Paul Philco322 - 04-28-2014, 08:13 PM
RE: My new 620B - by skyscraper - 04-29-2014, 01:18 AM
RE: My new 620B - by Eliot Ness - 04-29-2014, 11:52 AM
RE: My new 620B - by skyscraper - 04-29-2014, 12:38 PM
RE: My new 620B - by Arran - 04-29-2014, 09:41 PM
RE: My new 620B - by Arran - 04-29-2014, 09:48 PM
RE: My new 620B - by skyscraper - 04-29-2014, 10:15 PM
Philco 91 Tuning Condenser
