Philco model #?
Thats her I think.
thanks eX
Does anyone know how good of a performer this radio is?
Philco model #? - by OldRestorer - 04-29-2014, 06:24 AM
RE: Philco model #? - by exray - 04-29-2014, 06:39 AM
RE: Philco model #? - by OldRestorer - 04-29-2014, 07:00 AM
RE: Philco model #? - by exray - 04-29-2014, 07:21 AM
RE: Philco model #? - by Raleigh - 05-04-2014, 11:26 AM
There are currently 9746 online users. [Complete List]
» 1 Member(s) | 9745 Guest(s)
