And the rookie enters the game
For no larger than the patch is you could recycle a matching piece of veneer from a piece of old furniture, jewelry box or anything picked up at a flea mkt for a couple bucks. New unfinished veneer is harder to color match.
And the rookie enters the game - by TheBakery - 04-29-2014, 01:09 PM
RE: And the rookie enters the game - by tab10672 - 04-29-2014, 01:37 PM
RE: And the rookie enters the game - by TheBakery - 04-29-2014, 05:59 PM
There are currently 10185 online users. [Complete List]
» 1 Member(s) | 10184 Guest(s)
