My new 620B
By the way, the underside of your chassis is not untouched, I can see at least a few replacement paper caps mounted underneath, some may be to bypass failed block capacitors. It's been a while since I looked under the chassis of my 620B, most of it's issues are cabinet related, but the radio always worked so I never got around to working on the electrical part.
My new 620B - by skyscraper - 04-27-2014, 12:16 AM
RE: My new 620B - by Jamie - 04-27-2014, 06:42 AM
RE: My new 620B - by TA Forbes - 04-27-2014, 08:52 AM
RE: My new 620B - by Eliot Ness - 04-27-2014, 11:15 AM
RE: My new 620B - by Radioroslyn - 04-27-2014, 11:39 AM
RE: My new 620B - by PAradiogeek - 04-28-2014, 11:00 AM
RE: My new 620B - by skyscraper - 04-28-2014, 04:03 PM
RE: My new 620B - by Eliot Ness - 04-28-2014, 04:11 PM
RE: My new 620B - by Paul Philco322 - 04-28-2014, 08:13 PM
RE: My new 620B - by skyscraper - 04-29-2014, 01:18 AM
RE: My new 620B - by Eliot Ness - 04-29-2014, 11:52 AM
RE: My new 620B - by skyscraper - 04-29-2014, 12:38 PM
RE: My new 620B - by Arran - 04-29-2014, 09:41 PM
RE: My new 620B - by Arran - 04-29-2014, 09:48 PM
RE: My new 620B - by skyscraper - 04-29-2014, 10:15 PM
Philco 91 Tuning Condenser
There are currently 9036 online users. [Complete List]
» 1 Member(s) | 9035 Guest(s)
