44B or 18B?
Well the 18B only has a broadcast and a police band, like a Philco 60, but then again it has push-pull triode connected 42s driven by another 42, also a shadow meter, so it's a real thumper for audio. The 44B has four bands, like a 16B, but only has six tubes and a single ended power output stage. If you like raw audio power go for the 18B, if you like DXing, go for the 44B. I don't think that one is worth any more then the other, but the 44B is likely a rarer set.
44B or 18B? - by tab10672 - 04-29-2014, 11:27 PM
RE: 44B or 18B? - by Arran - 04-29-2014, 11:45 PM
RE: 44B or 18B? - by tab10672 - 04-29-2014, 11:52 PM
RE: 44B or 18B? - by TA Forbes - 04-30-2014, 12:28 AM
RE: 44B or 18B? - by Steve Davis - 04-30-2014, 08:01 AM
RE: 44B or 18B? - by tab10672 - 04-30-2014, 12:40 PM
Philco 91 Tuning Condenser
There are currently 9427 online users. [Complete List]
» 1 Member(s) | 9426 Guest(s)
