Philco Radio Repairman in Columbia, SC
Mikhail7 Wrote:
Texasrocker Wrote:... it is never a good idea to apply modern day ac voltages to any vintage radio chassis without fully re-capping the chassis 1st...
I and several other people just saw this lesson graphiclly demonstrated at an estate sale which had a lot of fine old tube radios from the 30's and 40's when some large klutz, who is at EVERY estate sale I've been to, horning in and blocking anyone else from having a sporting chance at finding a bargain had plugged in a late 30s vinatge RCA console. I happened into the room a couple minutes later. By then the radio was smoking. The lady who ran the sale came in and wanted to know how this happened. As I yanked the plug, I told who had unauthorizedly plugged in the set. He caught some grief from all of us. The pwr. tranny was smoked. Icon_evil
Mike
Moron! Of course he didn't buy it. They never do. I use a variac if I decide to bring one up at all. Check voltages without the rectifier tube installed. But, I haven't actually done that in years. If it needs recapping, then do it!
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
Philco Radio Repairman in Columbia, SC - by Guest - 07-28-2008, 05:19 PM
[No subject] - by Guest - 07-28-2008, 09:28 PM
[No subject] - by Texasrocker - 07-29-2008, 02:41 AM
[No subject] - by rghines1 - 07-30-2008, 12:06 AM
[No subject] - by Michael Dennis - 08-04-2008, 03:01 PM
[No subject] - by BDM - 08-05-2008, 01:07 AM
[No subject] - by Michael Dennis - 08-05-2008, 12:47 PM
There are currently 10160 online users. [Complete List]
» 2 Member(s) | 10158 Guest(s)
