I need a radio ID!
Ah! Thanks!
There is a radio inside of it, just not in the this photo. Haven't heard back from the seller, so it could be a moot point anyway.
I need a radio ID! - by captainslack - 04-30-2014, 04:36 PM
RE: I need a radio ID! - by vinzer - 04-30-2014, 04:49 PM
RE: I need a radio ID! - by OldRestorer - 04-30-2014, 06:06 PM
RE: I need a radio ID! - by Ron Ramirez - 04-30-2014, 06:09 PM
RE: I need a radio ID! - by captainslack - 05-01-2014, 11:59 AM
RE: I need a radio ID! - by TA Forbes - 05-01-2014, 01:04 PM
