Philco Power Transformer Part Number cross reference??
Hi
I'm assuming you are looking for something in table form, with a column headed PHILCO TRANSFORMER PART NO. and another headed USED IN PHILCO MODELS?
There is no such cross-reference that I know of. Someone with a LOT more time on their hands than I have would have to create one.
I have a 1950 Philco parts catalog, Glancing through it, it does list several Philco models of 1948 vintage, as well as a few 1949 and even a 1950 model, that uses this transformer. Tonight after work, if I don't forget, I can list some of these for you...
[No subject] - by Ron Ramirez - 08-05-2008, 06:32 AM
Reference materials - by theblurrrr - 08-05-2008, 04:55 PM
There are currently 6996 online users. [Complete List]
» 3 Member(s) | 6993 Guest(s)
