Gilfillan ??
Good looking set! ... I like it. Gillifan seems to be one of those companies that produced a lot of undocumented radios.
Gilfillan ?? - by Phlogiston - 05-01-2014, 05:52 PM
RE: Gilfillan ?? - by klondike98 - 05-01-2014, 06:15 PM
RE: Gilfillan ?? - by Jamie - 05-02-2014, 05:41 AM
RE: Gilfillan ?? - by OldRestorer - 05-02-2014, 06:16 AM
RE: Gilfillan ?? - by TA Forbes - 05-02-2014, 07:06 AM
RE: Gilfillan ?? - by Eliot Ness - 05-02-2014, 08:41 AM
RE: Gilfillan ?? - by morzh - 05-02-2014, 09:06 AM
RE: Gilfillan ?? - by Phlogiston - 05-02-2014, 11:30 AM
