stinky cabinet
Inserting some crushed charcoal briquets worked wonders on an old AK console cabinet for me...after cleaning the inside as best I could with a damp rag and some detergent. Let it set (in my case 30 days) for a while. Presto...wowso...the mouse odor was gone!
stinky cabinet - by murf - 02-16-2014, 09:43 PM
RE: stinky cabinet - by NostalgiaRadioTime - 02-16-2014, 09:53 PM
RE: stinky cabinet - by OldRestorer - 02-16-2014, 10:05 PM
RE: stinky cabinet - by Warren - 02-16-2014, 10:43 PM
RE: stinky cabinet - by morzh - 02-16-2014, 10:48 PM
RE: stinky cabinet - by murf - 02-16-2014, 11:16 PM
RE: stinky cabinet - by TheBakery - 04-28-2014, 02:51 PM
RE: stinky cabinet - by codefox1 - 04-29-2014, 01:01 AM
RE: stinky cabinet - by Art Hoch - 05-02-2014, 11:14 AM
There are currently 10048 online users. [Complete List]
» 2 Member(s) | 10046 Guest(s)
