New 44b
That is a nice radio.Icon_thumbup I had one once, wish I hadn't sold it.
M R Radios   C M Tubes
New 44b - by tab10672 - 05-02-2014, 05:32 PM
RE: New 44b - by Jamie - 05-02-2014, 05:54 PM
RE: New 44b - by Steve Davis - 05-02-2014, 05:57 PM
RE: New 44b - by tab10672 - 05-02-2014, 06:12 PM
RE: New 44b - by Steve Davis - 05-02-2014, 07:04 PM
RE: New 44b - by tab10672 - 05-02-2014, 10:25 PM
RE: New 44b - by OldRestorer - 05-03-2014, 12:50 PM
RE: New 44b - by gregb - 05-03-2014, 08:30 PM
RE: New 44b - by Jayce - 05-03-2014, 08:32 PM
Philco 91 Tuning Condenser
