Grill cloth Philco 90B
Indeed,I compared it with the 90B photo you had provided and few other originals, and it is very close.
Grill cloth Philco 90B - by fields 100 - 05-03-2014, 09:28 AM
RE: Grill cloth Philco 90B - by Eliot Ness - 05-03-2014, 10:55 AM
RE: Grill cloth Philco 90B - by fields 100 - 05-03-2014, 12:15 PM
RE: Grill cloth Philco 90B - by OldRestorer - 05-03-2014, 12:46 PM
RE: Grill cloth Philco 90B - by fields 100 - 05-03-2014, 12:54 PM
RE: Grill cloth Philco 90B - by morzh - 05-03-2014, 01:56 PM
RE: Grill cloth Philco 90B - by OldRestorer - 05-03-2014, 04:25 PM
RE: Grill cloth Philco 90B - by fields 100 - 05-28-2014, 05:19 PM
RE: Grill cloth Philco 90B - by TimC - 05-29-2014, 08:28 AM
RE: Grill cloth Philco 90B - by fields 100 - 05-29-2014, 08:41 AM
RE: Grill cloth Philco 90B - by TimC - 05-29-2014, 09:03 AM
RE: Grill cloth Philco 90B - by Steve Davis - 05-29-2014, 09:37 AM
RE: Grill cloth Philco 90B - by Eliot Ness - 05-29-2014, 09:43 AM
RE: Grill cloth Philco 90B - by fields 100 - 05-29-2014, 11:03 AM
