Grill cloth Philco 90B
There is a post here on the forums about the grill cloth toning I did a month or 2 ago but where I posted it is a mystery to me. All I did was lay the cloth down and give her a light mist of perfect brown toner. It gave the look of the original bronze color
See the toned cloth in my Aircastle and the untoned same cloth in my 84
Grill cloth Philco 90B - by fields 100 - 05-03-2014, 09:28 AM
RE: Grill cloth Philco 90B - by Eliot Ness - 05-03-2014, 10:55 AM
RE: Grill cloth Philco 90B - by fields 100 - 05-03-2014, 12:15 PM
RE: Grill cloth Philco 90B - by OldRestorer - 05-03-2014, 12:46 PM
RE: Grill cloth Philco 90B - by fields 100 - 05-03-2014, 12:54 PM
RE: Grill cloth Philco 90B - by morzh - 05-03-2014, 01:56 PM
RE: Grill cloth Philco 90B - by OldRestorer - 05-03-2014, 04:25 PM
RE: Grill cloth Philco 90B - by fields 100 - 05-28-2014, 05:19 PM
RE: Grill cloth Philco 90B - by TimC - 05-29-2014, 08:28 AM
RE: Grill cloth Philco 90B - by fields 100 - 05-29-2014, 08:41 AM
RE: Grill cloth Philco 90B - by TimC - 05-29-2014, 09:03 AM
RE: Grill cloth Philco 90B - by Steve Davis - 05-29-2014, 09:37 AM
RE: Grill cloth Philco 90B - by Eliot Ness - 05-29-2014, 09:43 AM
RE: Grill cloth Philco 90B - by fields 100 - 05-29-2014, 11:03 AM
