Radiola 18
Here's an accurate schematic:
http://www.nostalgiaair.org/PagesByModel...040317.pdf
Note it shows both the DC (top) version and the AC (bottom) version. You'll see the volume control labeled as such on the DC version, on the AC version it's in the same place but not labeled.
The following document might help you also, it has voltages, component values, and tips on the 18:
http://www.nostalgiaair.org/References/A...la18-2.htm
Radiola 18 - by AJboy123 - 05-03-2014, 05:17 PM
RE: Radiola 18 - by Jayce - 05-03-2014, 08:36 PM
RE: Radiola 18 - by BrendaAnnD - 05-03-2014, 08:46 PM
RE: Radiola 18 - by BrendaAnnD - 05-04-2014, 12:30 AM
RE: Radiola 18 - by AJboy123 - 05-04-2014, 01:06 AM
RE: Radiola 18 - by BrendaAnnD - 05-04-2014, 01:19 AM
RE: Radiola 18 - by Eliot Ness - 05-04-2014, 07:39 AM
RE: Radiola 18 - by AJboy123 - 05-04-2014, 11:32 AM
RE: Radiola 18 - by Eliot Ness - 05-04-2014, 12:11 PM
RE: Radiola 18 - by AJboy123 - 05-04-2014, 08:24 PM
RE: Radiola 18 - by Jayce - 05-04-2014, 08:55 PM
There are currently 3128 online users. [Complete List]
» 1 Member(s) | 3127 Guest(s)
