Finds inside radios?
Somewhere I saw a step-by-step description of a guy restuffing the 'lytic in a Zenith TO. He put a $1 bill in the restuffed cap along with a note. I think he said he puts a dollar bill in every cap he restuffs.
John Honeycutt
Finds inside radios? - by OldRestorer - 04-22-2014, 06:15 PM
RE: Finds inside radios? - by gregb - 04-22-2014, 06:25 PM
RE: Finds inside radios? - by TimC - 04-22-2014, 06:26 PM
RE: Finds inside radios? - by skyscraper - 04-22-2014, 06:57 PM
RE: Finds inside radios? - by PAradiogeek - 04-23-2014, 02:47 PM
RE: Finds inside radios? - by Art Hoch - 04-23-2014, 11:12 PM
RE: Finds inside radios? - by Art Hoch - 04-23-2014, 11:21 PM
RE: Finds inside radios? - by Art Hoch - 04-23-2014, 11:24 PM
RE: Finds inside radios? - by OldRestorer - 04-24-2014, 07:01 AM
RE: Finds inside radios? - by hsusmann - 04-24-2014, 07:26 AM
RE: Finds inside radios? - by Eliot Ness - 04-24-2014, 08:01 AM
RE: Finds inside radios? - by AI2V - 04-24-2014, 11:51 AM
RE: Finds inside radios? - by RadioDave - 04-24-2014, 01:23 PM
RE: Finds inside radios? - by morzh - 04-24-2014, 01:49 PM
RE: Finds inside radios? - by OldRestorer - 04-24-2014, 07:47 PM
RE: Finds inside radios? - by morzh - 04-24-2014, 08:22 PM
RE: Finds inside radios? - by Eliot Ness - 04-25-2014, 01:50 PM
RE: Finds inside radios? - by PhilcoJohn - 04-27-2014, 08:17 AM
RE: Finds inside radios? - by TA Forbes - 04-27-2014, 08:50 AM
RE: Finds inside radios? - by Jamie - 04-27-2014, 09:13 AM
RE: Finds inside radios? - by morzh - 04-27-2014, 10:17 AM
RE: Finds inside radios? - by thirtiesradio - 04-29-2014, 02:43 AM
RE: Finds inside radios? - by Raleigh - 05-04-2014, 10:42 AM
Philco 91 Tuning Condenser
There are currently 9817 online users. [Complete List]
» 1 Member(s) | 9816 Guest(s)
