Radiola 18
Goes to show you how long it's been since I have looked at a Radiola 17 or 18. Used to be common as dirt around here.
Radiola 18 - by AJboy123 - 05-03-2014, 05:17 PM
RE: Radiola 18 - by Jayce - 05-03-2014, 08:36 PM
RE: Radiola 18 - by BrendaAnnD - 05-03-2014, 08:46 PM
RE: Radiola 18 - by BrendaAnnD - 05-04-2014, 12:30 AM
RE: Radiola 18 - by AJboy123 - 05-04-2014, 01:06 AM
RE: Radiola 18 - by BrendaAnnD - 05-04-2014, 01:19 AM
RE: Radiola 18 - by Eliot Ness - 05-04-2014, 07:39 AM
RE: Radiola 18 - by AJboy123 - 05-04-2014, 11:32 AM
RE: Radiola 18 - by Eliot Ness - 05-04-2014, 12:11 PM
RE: Radiola 18 - by AJboy123 - 05-04-2014, 08:24 PM
RE: Radiola 18 - by Jayce - 05-04-2014, 08:55 PM
