Philco 90 with Twin 47 Tubes in PP
OK got that squared away New 700pf Cap and I had misread color code on resistor, turns out to be a 8.2K 1 W As Ron suggested.
NOW a new find, the Primary of the 2nd IF is open, NO easy repair, tried that
Need 2nd IF Coil Philco P/N 04320 . This is 260 KC IF Coil
Any out there on junkers.
Bob T
Nothing is EZ
Philco 90 with Twin 47 Tubes in PP - by joybird - 05-05-2014, 12:00 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 03:39 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 04:55 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-05-2014, 06:23 PM
RE: Philco 90 with Twin 47 Tubes in PP - by joybird - 05-05-2014, 06:42 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-05-2014, 07:05 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 07:45 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-05-2014, 09:45 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-05-2014, 09:49 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 10:37 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-07-2014, 02:21 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-07-2014, 11:48 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-14-2014, 11:15 AM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-14-2014, 02:11 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-14-2014, 04:22 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-15-2014, 01:26 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-16-2014, 01:09 AM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-17-2014, 02:40 AM
There are currently 10372 online users. [Complete List]
» 2 Member(s) | 10370 Guest(s)
