Finally got here.....with an armored escort!
I like the way it adheres to any surface too!
An asset when in a small cluttered room.
8)
Chuck
Philco 91 Tuning Condenser
There are currently 7185 online users. [Complete List]
» 3 Member(s) | 7182 Guest(s)
