Finally got here.....with an armored escort!
Lol you're close! Towel. Hand towel probably. Going to go to Jo-Ann fabrics to see if I can find something close
Philco 91 Tuning Condenser
There are currently 9442 online users. [Complete List]
» 1 Member(s) | 9441 Guest(s)
