Philco 111 Lowboy
I am impressed with the early 111 and 112 superhets. They receive well and sound good.
I have different model SW converters on some of my early BC-only high-tube count sets. They make good sets even better.
Philco 111 Lowboy - by palegreenthumb - 05-06-2014, 06:27 PM
RE: Philco 111 Lowboy - by OldRestorer - 05-06-2014, 06:58 PM
RE: Philco 111 Lowboy - by morzh - 05-06-2014, 08:51 PM
RE: Philco 111 Lowboy - by jerryhawthorne - 05-07-2014, 04:54 PM
RE: Philco 111 Lowboy - by morzh - 05-07-2014, 06:42 PM
RE: Philco 111 Lowboy - by TA Forbes - 05-07-2014, 08:39 PM
RE: Philco 111 Lowboy - by Arran - 05-08-2014, 10:23 PM
RE: Philco 111 Lowboy - by palegreenthumb - 05-10-2014, 02:20 AM
Philco 91 Tuning Condenser
There are currently 8474 online users. [Complete List]
» 3 Member(s) | 8471 Guest(s)
