Mother Nature Can Be Cruel!
Mike, I guess you were meant to have that radio unless he has doubled the price to make up for the destroyed merchandise. What is the current price and are you going to give it a new home.
Dave D
Mother Nature Can Be Cruel! - by Michael Dennis - 07-10-2008, 01:09 PM
[No subject] - by Dave D - 07-10-2008, 01:55 PM
[No subject] - by Michael Dennis - 07-10-2008, 02:30 PM
[No subject] - by Michael Dennis - 08-06-2008, 03:31 PM
[No subject] - by Dave D - 08-06-2008, 06:24 PM
[No subject] - by Michael Dennis - 08-06-2008, 07:04 PM
[No subject] - by Doug Houston - 08-09-2008, 12:44 AM
[No subject] - by Michael Dennis - 08-09-2008, 08:24 AM
There are currently 5579 online users. [Complete List]
» 4 Member(s) | 5575 Guest(s)
AvatarAvatarAvatarAvatar
