Philco 620 Tombstone
Hi Hunter,yeah the front looks fairly decent but the rest is spotty and the finish is peeling. Does yours have any label decals for the controls on the front?
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Philco 620 Tombstone - by 462ron - 04-24-2014, 08:38 PM
RE: Philco 620 Tombstone - by Jamie - 04-25-2014, 06:34 AM
RE: Philco 620 Tombstone - by 462ron - 05-05-2014, 07:56 PM
RE: Philco 620 Tombstone - by 462ron - 05-05-2014, 07:58 PM
RE: Philco 620 Tombstone - by TA Forbes - 05-07-2014, 08:36 PM
RE: Philco 620 Tombstone - by 462ron - 05-07-2014, 10:43 PM
RE: Philco 620 Tombstone - by hunter2115 - 05-08-2014, 09:33 PM
RE: Philco 620 Tombstone - by 462ron - 05-08-2014, 09:49 PM
RE: Philco 620 Tombstone - by Arran - 05-08-2014, 10:12 PM
RE: Philco 620 Tombstone - by 462ron - 05-08-2014, 10:24 PM
Philco 91 Tuning Condenser
There are currently 9180 online users. [Complete List]
» 1 Member(s) | 9179 Guest(s)
