Philco 620 Tombstone
Philco didn't use decals to denote controls on most models built before 1939, that includes the 610, 620, 623, 625, and 630. The only decal used was a copper foil block letter "Philco" decal above the speaker grille.
Philco 620 Tombstone - by 462ron - 04-24-2014, 08:38 PM
RE: Philco 620 Tombstone - by Jamie - 04-25-2014, 06:34 AM
RE: Philco 620 Tombstone - by 462ron - 05-05-2014, 07:56 PM
RE: Philco 620 Tombstone - by 462ron - 05-05-2014, 07:58 PM
RE: Philco 620 Tombstone - by TA Forbes - 05-07-2014, 08:36 PM
RE: Philco 620 Tombstone - by 462ron - 05-07-2014, 10:43 PM
RE: Philco 620 Tombstone - by hunter2115 - 05-08-2014, 09:33 PM
RE: Philco 620 Tombstone - by 462ron - 05-08-2014, 09:49 PM
RE: Philco 620 Tombstone - by Arran - 05-08-2014, 10:12 PM
RE: Philco 620 Tombstone - by 462ron - 05-08-2014, 10:24 PM
Philco 91 Tuning Condenser
There are currently 4007 online users. [Complete List]
» 1 Member(s) | 4006 Guest(s)
