  • 1 Vote(s) - 5 Average
Philco model 70 rebuild - by Tim P.
#90
I have tested this on and off as much as I could this week. I reconnected the original bias resistor last night, but I didnt notice any major difference, although I thought I heard 'the sound'. This evening, I powered up and immediatly heard the noises & saw erratic current fluctuations. I powered down and temp installed a 68ohm resistor. So far so good. With it being intermittent, it is really hard to tell quickly of the problem is really solved or if it is just 'deciding' to work for the time.
When I checked the F-G, I had one of the wires disconnected. I think the problem is in that bias resistor. I dont know if I should replace only the bad section or if I should replace it all. Tell ya, if this is the problem, this one should go in the record books!
Tim
Philco model 70 rebuild - by Tim P. - by TV MAN - 01-29-2014, 11:46 AM
RE: Philco model 70 rebuild - by Tim P. - by TV MAN - 05-09-2014, 08:48 PM
Users browsing this thread: 20 Guest(s)
