Philco 37-620 Chairside
Thanks! I'm pretty well set up for Philco schematics and info.
Have not started it yet, will be glad to post photos when I do.
Philco 37-620 Chairside - by TA Forbes - 05-02-2014, 09:20 PM
RE: Philco 37-620 Chairside - by TA Forbes - 05-02-2014, 09:22 PM
RE: Philco 37-620 Chairside - by Warren - 05-02-2014, 09:29 PM
RE: Philco 37-620 Chairside - by Ron Ramirez - 05-02-2014, 10:01 PM
RE: Philco 37-620 Chairside - by TimC - 05-02-2014, 10:02 PM
RE: Philco 37-620 Chairside - by tab10672 - 05-02-2014, 10:37 PM
RE: Philco 37-620 Chairside - by TA Forbes - 05-02-2014, 10:48 PM
RE: Philco 37-620 Chairside - by gregb - 05-02-2014, 10:57 PM
RE: Philco 37-620 Chairside - by OldRestorer - 05-03-2014, 06:36 AM
RE: Philco 37-620 Chairside - by rocklandman - 05-03-2014, 08:18 AM
RE: Philco 37-620 Chairside - by Radioroslyn - 05-04-2014, 12:40 PM
RE: Philco 37-620 Chairside - by morzh - 05-04-2014, 05:45 PM
RE: Philco 37-620 Chairside - by Giganx - 05-10-2014, 01:16 AM
RE: Philco 37-620 Chairside - by TA Forbes - 05-10-2014, 10:03 AM
RE: Philco 37-620 Chairside - by OldRestorer - 05-10-2014, 09:03 PM
RE: Philco 37-620 Chairside - by Gene Pederson - 05-14-2014, 11:24 AM
RE: Philco 37-620 Chairside - by Randy H. - 06-08-2014, 02:54 PM
RE: Philco 37-620 Chairside - by TA Forbes - 06-08-2014, 10:26 PM
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
There are currently 2902 online users. [Complete List]
» 2 Member(s) | 2900 Guest(s)
