Chassis Detailing or not
Personally, I do not polish or paint the chassis or IF cans etc. I will clean the chassis and touch up any rust spots with aluminum paint to match and blend with the surrounding area.
Originally the aluminum parts were raw aluminum and while somewhat shiny, most did not have a mirror polished appearance. I prefer to maintain the original look as much as possible. Something that is 80 years old should gracefully show its age just a bit.
Chassis Detailing or not - by 462ron - 05-09-2014, 09:00 PM
RE: Chassis Detailing or not - by 37silverstreak - 05-09-2014, 09:22 PM
RE: Chassis Detailing or not - by Ron Ramirez - 05-09-2014, 09:57 PM
RE: Chassis Detailing or not - by gregb - 05-09-2014, 11:06 PM
RE: Chassis Detailing or not - by 462ron - 05-10-2014, 12:55 AM
RE: Chassis Detailing or not - by Eric Adams - 05-10-2014, 10:46 AM
RE: Chassis Detailing or not - by Mondial - 05-10-2014, 11:04 AM
RE: Chassis Detailing or not - by OldRestorer - 05-10-2014, 08:58 PM
RE: Chassis Detailing or not - by exray - 05-10-2014, 09:49 PM
RE: Chassis Detailing or not - by gregb - 05-10-2014, 11:44 PM
RE: Chassis Detailing or not - by Eric Adams - 05-10-2014, 11:51 PM
RE: Chassis Detailing or not - by gregb - 05-11-2014, 12:03 AM
RE: Chassis Detailing or not - by Arran - 05-11-2014, 12:09 AM
RE: Chassis Detailing or not - by Warren - 05-11-2014, 02:40 AM
RE: Chassis Detailing or not - by PhilcoJohn - 05-11-2014, 07:56 AM
RE: Chassis Detailing or not - by codefox1 - 05-11-2014, 09:34 AM
RE: Chassis Detailing or not - by gregb - 05-11-2014, 10:56 AM
RE: Chassis Detailing or not - by Groundhog74 - 05-11-2014, 06:06 PM
RE: Chassis Detailing or not - by 462ron - 05-11-2014, 06:43 PM
RE: Chassis Detailing or not - by Warren - 05-12-2014, 01:30 AM
RE: Chassis Detailing or not - by codefox1 - 05-12-2014, 11:33 AM
RE: Chassis Detailing or not - by gregb - 05-12-2014, 11:47 AM
RE: Chassis Detailing or not - by Warren - 05-12-2014, 02:35 PM
RE: Chassis Detailing or not - by Jamie - 05-12-2014, 04:26 PM
Philco 91 Tuning Condenser
There are currently 5183 online users. [Complete List]
» 3 Member(s) | 5180 Guest(s)
