Philco 59c
On a closer look I think I can answer my own Question #2; the schematic actually indicates cap 19 as 1,000 uuF which would be 0.001uF. The parts list probably is in error. Still looking for an under chassis photo.
Thanks!
Philco 59c - by klondike98 - 05-10-2014, 02:14 PM
RE: Philco 59c - by klondike98 - 05-10-2014, 03:14 PM
RE: Philco 59c - by klondike98 - 05-10-2014, 03:39 PM
RE: Philco 59c - by morzh - 05-10-2014, 03:45 PM
RE: Philco 59c - by klondike98 - 05-10-2014, 05:58 PM
RE: Philco 59c - by morzh - 05-10-2014, 09:17 PM
RE: Philco 59c - by klondike98 - 05-10-2014, 10:04 PM
RE: Philco 59c - by klondike98 - 05-30-2014, 06:38 PM
RE: Philco 59c - by gregb - 05-30-2014, 06:45 PM
There are currently 10215 online users. [Complete List]
» 1 Member(s) | 10214 Guest(s)
