Knob shaft doesn't turn tuning coil
Finally brought the Philco 71 back after a stay at my buddy's place getting repaired. Once home, I hooked it up to my signal generator to get it fine tuned. Turned the knob to the bottom of the AM band to run the signal test, but I went a little too far past the end of the dial. Suddenly, I couldn't tune the radio anymore even though the knob still wound. I assumed the dial cord had come off it's pulley, but that wasn't the case. Seems the shaft that the knob sits on no longer turns the turning coil. I can move the coil manually and everything works fine, but the knob shaft only spins by itself.
Any ideas on what might have happened or how to fix this?
Knob shaft doesn't turn tuning coil - by captainslack - 05-10-2014, 05:21 PM
There are currently 7646 online users. [Complete List]
» 4 Member(s) | 7642 Guest(s)
AvatarAvatarAvatarAvatar
