Chassis Detailing or not
I like to get rid of deep rust and pitting from "guests" or leaking capacitors by steel wool or abrasive stones, and as said already, some similar colored paint in the affected area(s.) If a chassis is totally stripped (as in repurposing an old organ amp into a guitar amp,) I'll shine it up or paint it as needed.
Chassis Detailing or not - by 462ron - 05-09-2014, 09:00 PM
RE: Chassis Detailing or not - by 37silverstreak - 05-09-2014, 09:22 PM
RE: Chassis Detailing or not - by Ron Ramirez - 05-09-2014, 09:57 PM
RE: Chassis Detailing or not - by gregb - 05-09-2014, 11:06 PM
RE: Chassis Detailing or not - by 462ron - 05-10-2014, 12:55 AM
RE: Chassis Detailing or not - by Eric Adams - 05-10-2014, 10:46 AM
RE: Chassis Detailing or not - by Mondial - 05-10-2014, 11:04 AM
RE: Chassis Detailing or not - by OldRestorer - 05-10-2014, 08:58 PM
RE: Chassis Detailing or not - by exray - 05-10-2014, 09:49 PM
RE: Chassis Detailing or not - by gregb - 05-10-2014, 11:44 PM
RE: Chassis Detailing or not - by Eric Adams - 05-10-2014, 11:51 PM
RE: Chassis Detailing or not - by gregb - 05-11-2014, 12:03 AM
RE: Chassis Detailing or not - by Arran - 05-11-2014, 12:09 AM
RE: Chassis Detailing or not - by Warren - 05-11-2014, 02:40 AM
RE: Chassis Detailing or not - by PhilcoJohn - 05-11-2014, 07:56 AM
RE: Chassis Detailing or not - by codefox1 - 05-11-2014, 09:34 AM
RE: Chassis Detailing or not - by gregb - 05-11-2014, 10:56 AM
RE: Chassis Detailing or not - by Groundhog74 - 05-11-2014, 06:06 PM
RE: Chassis Detailing or not - by 462ron - 05-11-2014, 06:43 PM
RE: Chassis Detailing or not - by Warren - 05-12-2014, 01:30 AM
RE: Chassis Detailing or not - by codefox1 - 05-12-2014, 11:33 AM
RE: Chassis Detailing or not - by gregb - 05-12-2014, 11:47 AM
RE: Chassis Detailing or not - by Warren - 05-12-2014, 02:35 PM
RE: Chassis Detailing or not - by Jamie - 05-12-2014, 04:26 PM
Philco 91 Tuning Condenser
There are currently 3722 online users. [Complete List]
» 2 Member(s) | 3720 Guest(s)
